Very Quick Request of a Fellow Owner
MiddKid
WA
Sorry to split this out into its own thread, but thought I'd call attention to my request that is buried in the linked thread below.
Simple request: Turn on your 2018 Expedition in Accessory Mode (power on with your foot off the brake, no engine). Does your main display throw the "system fault" I included in the attached picture? Thank you in advance! I'm going to the dealer tomorrow for another issue and I'm very curious if this is a problem with my truck or if it's just a quirk of the new model as hypothesized in the thread:
http://www.expeditionforum.com/threads/drive-mode-selection-system-fault.34493/
TxBrian
DFW
Mine doesn't fault either, just shows full accessory power active or something like that.
J Ski
3.5plati
VA
Are you in 4 or 2 wheel drive when this pops up?
shane_th_ee
Seattle
Throws the same fault in both 2H and 4A.
Taking it in today...thank you @jgudnason and @Brian Corr for confirming it doesn't happen on yours!
But J. Ski is thinking that Brian Corr and jgudnason had theirs in two wheel drive mode... Which would change the ECUs expected responses from the transfer case/center differential.
M
MiddKid
WA
After spending the day at the dealer...
The truck isn't showing any faults on their computer. The tech tried to use the "it will always give that message when the engine isn't on." I mentioned that I asked online and others don't have the issue (thanks everyone). They've escalated it to Ford (along with my USB issue). Expect to hear back in a few days...
edyk1986
