Thanks. I'm not sure about the first time because it kinda caught me off guard. The second time I was cruising around 40-50. Not sure about whether I was shifting up or down. Today it happened at around 60. I think i was downshifting.When does it clunk? Slowing down, speeding up, both? Engine/Trans cold or hot? What gear is it in when it clunks?
I'll take a look at this after work. Unfortunately I don't have a scanner anymore. No idiot lights have come on.Good advice. Can you scan for codes?
This^^.The truck is now a few years old, the vacuum hubs are probably losing vacuum and half engaging on the fly and will produce hard loud clunking. Almost feel like you are running something over when it happens in front?
It’s likely a leaky hub actuator seal or the solenoid on the firewall. Common issue of ford half tons.
That's exactly how it feels!The truck is now a few years old, the vacuum hubs are probably losing vacuum and half engaging on the fly and will produce hard loud clunking. Almost feel like you are running something over when it happens in front?
I was watching some videos and maybe this is the problem. I bought the car back in 3/18. I pretty much only had it on 4wa until last week when I switched it to 2wd. Then a few days later the problems started.The truck is now a few years old, the vacuum hubs are probably losing vacuum and half engaging on the fly and will produce hard loud clunking. Almost feel like you are running something over when it happens in front?
