tinkering
1997 Expy 5.4
The drivers side exhaust flange is leaking badly; it fills the cab with fumes . I bought it that way.
I went under and noticed one stud has rotted right off. The other stud shaft is getting mighty thin.
The passenger side studs are still holding so I might do them later unless I have to drop both sides to get at the passenger side flange.
* I assume they are studs that are threaded into the manifold side? They look so deteriorated that I am expecting to have to remove them by some means other than simply backing them out.
* I can get oxygen for my propane oxygen torch. Heat them up and shock them back with a wet cloth, then attempt to back them out with vice-grips or an extractor.
* I can drill them out IF THERE IS ROOM TO GET IN THERE?
What's the best bet?
Should I replace them with studs or just use nuts and bolts to ease the job next time?
Should I just take it in to the muffler shop and pay them to take my problem?
NB: I notice a couple of broken exhaust manifold studs; one on each bank at the rear, that I was just going to leave for the time being. I would like it back on the road without having to do that job right away too. Are these Expys notorious for rotting out like this?
