Steve Hartman
OMG! I bought a 99 Super Duty and can't afford to drive it! I have a 2001 Expy with 265K on it that has run like a top since I got it with 135K on it. (12-15 MPG depending on how heavy my foot is. Never had a trouble light! Drove the SD 173 miles and used 29.2 gallons of gas, for an average of just under 6MPG. My Expy is old and beat up body wise and I'd probably be lucky to get $2500 for it. But the drive train is very trustworthy. So I'm wondering if I could do an entire swap of engine, tranny, and xfer case.
I guess my first question is... is it doable and how hard would it be. I know the blocks are the same except for the two added cylinders. What I don't know is - are they added to the front of the block or the rear. I'm worried about motor mounts.
Second, my 2001 Expy has electronic AWD to 4WD and the SD is manual. Would I have to use the old transfer case and would it fit the tranny off the Expy?
And speaking of transmissions (believe SD has 4R100 with big pan bubble)
Would the 5.4 underpower the SD or did they make some with the 5.4?
Thank you in Advance! I appreciate it!
