Sorry about the gloom & doom, one of those traits passed down from mom. As for electrical experience, I fully understand house electrical. BUT, mainly you got 3 wires, and they're all either black, white or ground. In the darn car seems like there are thousands, and you have no easy way of knowing where they run and if there some freaking connector, relay or switch that's causing the problem. If electrical repair was documented like how to replace a wheel hub, I'd be golden!
OK, I need you to follow-up on a request from yesterday - "With the ignition switch disconnected see if you have power on both sides of fuse 13 in the cjb."
I not sure I did this test correctly. I actually pulled fuse 13 and then placed the red probe in the vacated fuse spot on the CJB and the black probe into the ground for the CJB. Was this correct?
I "think" my meter will measure current, if not, I'll get one that does.
And thank you for the documents you sent.
