2007 engine power issues
Kennyb65
Allen, Texas
Hello, my 2007 EL limited has developed a ticking noise and it also has low power while driving. It has 118k miles, no codes, have changed the spark plugs, oil and added Lucas oil stabilizer. I have a code reader that I can view live data with while running. In the drive way and revving the engine, the timing advances to 40 and stays there. When driving the timing drops to 0 and less and it takes a while to get to 60 mph.
Any ideas?
K
Kennyb65
Allen, Texas
okay, I checked the torque and no change. I am suspecting the right phaser wheel is making the clicking noise. I am also thinking I may have a vacuum leak. I'll check for that today.
K
Kennyb65
Allen, Texas
Just to close this out...
My problem was a bad rocker arm on the #1 cylinder. Replaced it and the expedition runs like new. My assumption is that the rattling of the rocker triggered the anti-knock sensor and it retarded the timing.
Glad you found your problem. I don't know about a loose rocker causing a knock sensor to retard timing, but hell anythings possible on a computer controlled vehicle. The worn rocker kept that valve from opening and closing properly, leading to loss of compression/ power on that cylinder. How did he find the worn rocker?
