762mm
The 6R80 goes nuts after a dead battery. Was there a battery problem recently?
Who told you that?
I have a battery disconnect switch on mine that I routinely use when I drive my other vehicle to work and the Expy is not driven for a week or two.
The battery gets 100% disconnected regularly, to prevent parasitic drains. Zero problems thus far... I reconnect the negative cable when I'm ready to drive the Expy, start her up and it drives / shifts just fine.
As for 6R80 reliability, the general consensus is that they should last at least 200,000 miles with no abuse. Even my ex-cop car SSV with 132,000 miles on the clock and no fluid / filter change (until I did it this summer) is running just fine with zero issues... and I assume it already had a pretty hard life.
The great thing about having an F-150 truck (or F150-based Expedition) is that these parts are plentiful in junk yards, for cheap. They are also quite easy to work on if you're gonna swap it out yourself or get it done, compared to some other mechanical nightmares out there!
