New Transmission Time, exactly what they are doing. Hence we don’t understand why you guys are blasting the shops diagnosis.
Because a large majority of the time Transmissions do not need a complete rebuild nor does a vehicle need a new transmission. It simply needs a more minor repair. Some shops know this some shops don't. Diagnosing and fixing transmissions is a lost art today. But regardless, all they're going to do is tell you you need a rebuilt so they can make the good money. They get a huge, huge, huge profit margin on a rebuild your transmission.
Would anyone like to actually discuss cost of the master rebuild kit and a torque converter for one of these Transmissions?
And we could discuss flushing out the trans cooler and the radiator which some do or removing it and adding auxiliary cooler or replacing the radiator, all three fairly common options but let's talk about actual expenses incurred. Then let's talk about their actual Builder who there's usually only one guy in the shop who is the master builder who knows how to do it and what he makes per hour. The other guys and a lot of the young ones simply remove and install them.
So let's look at the numbers and compare this to what an auto garage makes when they replace an alternator on your car. You will soon see that the number show the transmission shops to be the biggest Crooks in the industry. Body repair and paint refinishing comes in number two as far as profit margin but at least there's is a very high-quality finesse delicate work that people expect perfection in the look and finish.
We can go back to the days of building houses and remodeling and doing roofs and stuff where it used to be if the materials for something were $5,000 if you can get the whole job done for 10000 or less. No one had the nerve 2 ever charged double labor and most were well under that. Now there are no rules. You can charge anything you want. Whatever the market will bear.
Body shops justify this because of all the hours of Labor they put into it. This is 2020, they should have sped up the process of sanding a fender and stuff with tools and everything we have today and they've been doing the same way for decades. Also, they don't actually do that much sanding and stuff today like they used to. If the fender has anything over a paintless dent removal pop out Dent, they replace the fender. They're almost always painting perfectly prepped straight ready to paint panels.
The people that earn their money are the guys that do Restorations and frame off an old rusted out cars. These guys spend a lot of time finessing everything to get it perfect.
I don't care how many hours you put into something, if you only have $500 in materials then no way can you justify a $5,000 bill.
