1. Pick up the compression tester. Their should be a little valve. it looks like the inside of the tire valve. You will need to remove that valve.. A bike shop has a tool for that, or the local parts store. Go to the isle that has tire related things (or ask the guy at the counter) Their may be a kit that has replacement valves plus tire valve caps etc. Some of these kits have the valve remover.
Hear is a link for suck a goodie from my local store.. This will give you an idea of what I am talking bout.
2. Pull the off and set aside.
3. Remove the spark plug.
4. Find a socket that fits the harmonic dampener pulley. It's a big bolt. The pulley is the very bottom on the engine. The bolt could be as big as 20mm up to 1 1/4 inch.
5. screw in the compression tester hose into the hole.
6 Hold your thumb on the other end, and turn the socket. By doing this. You will feel pressure build up. This lets you know that valves are closed. You should also feel the socket on the pulley bolt turn hard, then real easy. AT THIS POINT. STOP TURNING THE SOCKET.
7. Now remove the compression hose.
8. insert a long flat blade screw driver in the hole. You should be able to feel the piston. if the screw driver falls in with out stopping. You will need to move the piston up more.. SEE STEP 8a
8a. turn the socket on the pulley till you see/feel the screw driver move up.. YOU DO NOT NEED TO TURN THE CRANK FAST. BY DOING THIS FAST WILL DAMAGE TOP OF PISTON. When the screw driver stops moving up and starts done. STOP. YOU ARE NOW TOP DEAD CENTER.
10. reinstall compression hose. attach air hose..
11. make sure air tanks are set to 75 to 100 psi and far enough away. This will give you quite time to hear air leaks.
12. start compressor. let air build up in the cylinder (bout 5 min should be more then enough)
12. listen for air leaks..
13. open oil fill cap. listen. ( possible bad piston rings. Rebuild motor)
14. open coolant over flow and listen. (warped head, head gasket, bad valve)
15. take apart intake hoses.
16. Pull throttle and listen. (warped head, bad valve, head gasket.)
17. write down Cylinder number and were you heard the air. (oil, TB, water.)
18 repeat proses for all cylinders.
If you hear air from coolant over flow, or TB. You need to have the head fixed up. You will need to pull the top end of the engine apart to get to heads. Take the heads to a machine shop and have them worked on..
If you hear air from the oil fill tube. You will need to rebuild the engine or buy another one. This is an indication of bad rings, or scored cylinder wall.
DISCLAIMER. YOU WILL NEED BOTH HEADS DONE. WHEN THE HEAD COMES OFF. THEY WILL NOT FIT BACK ON CORRECTLY UNTIL THEY ARE "DECK" OR "MILLED". THIS IS DONE BY THE MACHINE SHOP..
