- Joined
- Nov 23, 2014
- Posts
- 5,981
- Reaction score
- 1,338
The black relay is obviously your turn signal one. Pull the plug on it, and with the key on, one lead should have 12 volts, the other should light your light when you turn signal right or left. Do that before changing multi switch on column. Also make sure the relay you tried has the same number on it, 87 and so on. And that it's a good one. Probably is if that circuit is working.
