homermandy
1998 5.4 Expedition. Just replaced engine and put in new compressor, dryer, condensor, all hoses, etc. The A/C clutch is not engaging. Here is what I have done and found.
There is NO voltage to the low pressure cutoff switch on the accumulator. None. I jumpered 12V to the cutoff switch and then jumpered the 2 wires on the cutoff switch and the compressor engages. So I know the problem is between the control in the dash and the cutoff switch,
I followed procedures in the service manual to check voltage at the switch as well as resistance of the switch. All is good.
But I cannot trace where this wht/red wire gets power from. I checked continuity of all fuses in the cab as well as the power distribution box and all checked out.
Is there a specific relay that would provide power to this switch. It should have 12V when A/C is engaged but it does not.
I am stumped.
Please help.
I am stumped.
Please help.
