dimension12
Can anyone tell me where all the chassis grounds are located? 99 EB with 5.4 4x4. With the stalling and multiple codes of different areas makes me think I have a ground issue. Crawling under truck and tracing wires today.
Thank you. I have new battery cables coming. They are very corroded and I will be able to clean all the ground connections durring installation. Just recently the OD off light started flashing. When I put it in Neutral and shut it off then restart, while driving, the OD off light stops flashing and the abs light goes out for a few miles. Drove with fuel pressure gauge and is within spec. I get coil codes, cyl head too hot codes, fuel tank purge codes, long trim stays around 10 and 1 downstream O2 intermit. shows N/A.
