LEOL
Against my nature ill keep this short and simple as possible.
Did a compression test, (2006 5.4 3v, 172000k miles).
Results were 160psi accross the board, EXCEPT Cyl #2 (150psi) and #5 (150-155psi)
#2 cyl is known to have possible but unconfirmed damage or issues from a sparkplug meltdown/implosion of unknown cause.
have run vacuum tests, which do indicate issues, but dont seem to indicate valve or major ring problems, or head gasket leakage (though im still sorting out what exactly the readings are really telling me).
The compression range at which is "acceptable" by written diagnosing standards is 75%... which both #2 & #5 pass with flying colors, especially considering the mileage on the engine.
disregarding the vacuum test, and other things i've left out on this post... my question is...
in this scenario 10psi is roughly 6% of the allowed 25% ratio difference, so... under circumstances in which internal damage isnt already known, would a compression reading of 10psi in one or two cylinders be much cause for concern about possible internal damage, and/or being the primary issue with the current drivability power loss?
