R&T Babich
I was changing transmission fluid, like I have done several times before.
Trans has been working fine, just time for a fluid change.
I pulled a cooler hose and added a drain hose.
I was pumping fluid into a container while replacing fluid via the filler tube.
The hose got kinked and the fluid stopped flowing into the container.
After stopping the engine and cleaning up the mess I set up to resume.
Now the trans fluid is not flowing out thru the cooler hose.
Did I blow some sort of pressure valve in the trans?
The trans shifts into gears, but now no fluid is flowing thru the cooler line.
