Thermo
technical advisor
- Joined
- Apr 18, 2011
- Posts
- 1,407
- Reaction score
- 65
From my experience with a 4" lift, 315/75R16's are as big as you can fit without any modification if you are using an 8" wide rim with 4.5" backspacing. Going with a wider rim will result in rubbing, but this can be overcome with modifying the rear of the front wheel wells and trimming the front valance some. STepping up to 36's is most likely going to result in rubbing unless you do a lot more. Now, this all assumes no rubbing under any condition. Sure, I am running 37x12.5's and I have done a significant amount of modification and have a very specific setup that only works as I have it. Any change and it wouldn't work. Going with a rim wider than 8" with any 35" or larger tire is that the tire will start to rub on the outside edge of the rear wheel well unless you have adequate lift. For a 35" tire, that is atleast 4" of lift. I tuck my 37's by 1" with only 4" of lift.
Hopefully this gives you an idea of what needs to be done. IF you have more questions, just ask.
