Knock is there not quite as deadening. Grasp in the dark. I regapped plugs to .052. While I was at it I did an ohm test on all cop. Passenger side all cop measured .8 driver side ranged from 1.1 to 1.3 ohms. Question is even though I'm not getting any misfire codes could the driver side cops primary winding COATING melt and cause an engine knock -- due to weak spark? I'm desperate that's why I'm pounding my head. It almost seams that if it was a rod, bearings or what have you the freakin motor would've locked up already. Any suggestions? Lastly my manual says that the ei cop should read .55 ohm
