Engine Missing????
michaelmagorian
Menominee, NE
Alright so here's the deal, I have a 5.4 Eddie Bauer I have only had for a few months. When I went to look at it, it was missing and the guy threw in a couple of coil packs and two plugs, and then everything was fine. The check engine light came on a month later, but I didn't really care because it was running fine. Then it started to miss badly. We hooked it up to a scanner and it gave lean codes in bank two. EGR is fine, compression checked fine, plugs are good, and starting to wander what else I'm missing. Any help would be greatly appreciated.
BAD RONALD
Fairfield CT
Do yourself a favor and do search for threads on the specific diagnostic trouble codes displayed. You will be able to access as much information as you wish to read.
Try the search function on this site first, then go to the web.
Not trying to be a smart ass here. There is a ton of material to review on this common problem while waiting for a response from this board.
Bedrck47
Elizebethtown, PA
What year is the expy and what was the code that showed
Post that information and I look it up in the service manual
Also some good advice from BAD RONALD ton of good information available
BAD RONALD
Fairfield CT
... I have a 5.4 Eddie Bauer I have only had for a few months. When I went to look at it, it was missing...
I hate it when this happens:
" I remember I had that 5.4 when I drove home last night.. what the f*** did I do with it??? Anybody see a 5.4 lyin' around?"
M
michaelmagorian
Menominee, NE
Thanks I did the search and it sounds like I need to pressure check the fuel and make sure that either the pump hasn't crapped out or there is a problem with the fuel line somewhere. Now at least I have a good starting point.
Bedrck47
Elizebethtown, PA
Again I ask what was the code that came up
The information that you give will help others help you Most important is the year
If you had codes come up its always a good idea to put them in your post
