Indicator LED is in the main light switch.
Fuse 9 should be hot at all times. Check for power on both sides of the fuse with the fuse in place.
At the fog lamp relay, good fuse in #9, check for power at pin #3 on the relay - (may also be #30).
Are you familiar with a relay pin out? For example what #85, #86 is?
