ForScan Tweaks - 2015+
ExpeditionAndy
Fort Wayne, Indiana
I figured that I'd give this one a bump. I am working on comparing the codes from the Explorer and the F150 to see if there is commonality of the codes. I will post a spreadsheet highlighting the ones that seen common to both. Then it will be a simple matter of seeing if they work on my Expedition.
Cy Webit
Southern NJ
I've been playing with ForScan on my 2016 Expy EL, made some changes that worked fine (got them from F150 forums), but I cannot for the life if me affect a change to the 12V cig lighter on the dash. I want it to cycle on/off with the engine. Right now it never times out, it is always powered up!
I've tried several different numbers: 726-39-01-0001-0068, none seem to make any difference? Could it be my cheapo OBD adapter can't write properly to that section? My ForScan doesn't allow me to write (change data) to any fields other than 2 I bolded above? Anyone got any suggestions?
LokiWolf
LokiWolf
Super Moderator
Super Moderator
Richmond VA
Yeah, all modules from the 150 do not match up with the Expy...as in revision. It might be hardwired in our and not controlled by a module.
powerboatr
North East Texas
thats odd about the cigar lighter 12v
my 2010f150 it cut off after a time period
2013 f150 it was hot all the time.
havent looked at the expy yet.
LokiWolf
LokiWolf
Super Moderator
Super Moderator
Richmond VA
That actually makes this make more sense. Our 15-17 Expy's are more closely related to the 2013/2014 F-150's than any other vehicle, minus Sync 3 of course.
Cy Webit
Southern NJ
Hey Powerboater, I would appreciate to know if your 12v cig lighter on the dash times out or not. If it does, can you use ForScan and post your numbers for that block?
Thanks
AK_Zack
Southeast Alaska
So I got the Bluetooth obd adapter and got it synced to my surface book, and got the forscan program, but I can't figure out how to change settings.. any chance you could give some pointers? @LokiWolf
LokiWolf
LokiWolf
Super Moderator
Super Moderator
Richmond VA
In Order to change settings you need to request a Full License. On the Forscan site, there is a process.
powerboatr
North East Texas
Thanks
i have to go see. I have been not paying much attention here latley sorry
the_plugger
