Heated/Cooled seats
rollinstone
Seattle
I have a 2014 LTD with heated 2nd row seats. Left 2nd row seat heater switch just flashes once when it's toggled and goes out. Would that switch also be controlled by that module under the front seat?
ManUpOrShutUp
PA
Without looking in the manual I would guess that it does not. The climate-controlled setup in the front is an air-based system whereas the second row uses a standard coil/heating pad type setup. To be sure though, you can probably pickup a service manual via eBay on the cheap.
Bedrck47
Elizebethtown, PA
You would have better results had you started a new thread about your problem
The OP in this thread had a 2008 expy and his problem was with the front seats.
Your problem is different as it concerns the 2nd row heated seats plus yours is a 2014
To answer your question There is no connection between the front row and the 2nd row modules
cyclesomatic
Indiana
Just bought a 2008 EB with this exact same problem. Both seat heating/cooling inoperable and the lights come on and flash for a couple seconds and go out.
Just thankful there are people sharing info like this. I'll troubleshoot it sometime in the next week or so and post my findings with images.
To the OP Tj Toronto: Any updates on your situation?
T
TJ Toronto
Toronto
Good Morning Cyclesomatic,
Welcome to the group.
Unfortunately I’m still with no working seat. There have been quite a few days recently where I would have loved to have it that’s for sure! I look forward to your findings.
Thanks Again
TJ
deweysmith
Montreal, QC
If either of you can get codes pulled from the body modules, there should be some set for the seats, unless the control modules are bad.
mbed
SE PA
there are quite a few issues from poor grounds or wire splice corrosion...my 08 has many.
T
TJ Toronto
Toronto
For me though, it’s only my driver seat heat and cool that’s not working. The passenger side works fine.
