tjenkse
I'm having a problem removing the ignition lock cylinder in my wife's '99 Expedition EB.
The procedure is to turn the key to the run position and insert a small tool in the hole underneath the cylinder, depress the retaining pin and pull the cylinder out. When I depress the retaining pin, I can pull the cylinder a small fraction of an inch and no further. I've tried turning the key from ACC to START several times to no avail. Is it hanging on something? What else could I try.
