2004 XLS with 4.6l at about 180K
bought new and had some issues
New plugs at 80K at dealer
102k it blew a plug out. took it to dealer because i wanted it done right. Long story short i believe there was al chips on top of piston and first 45 miles after work blew a hose in piston. also had all new injectors installed at same time, and all new rubber. got a ford reman engine and the ford reman had a tick and the cam hold down was cracked, got a new cylinder head under warranty.
Then the cats had issues because of the oil dump. replaced with walkers and the one failed relatively quickly and replaced under warranty. And all new motorcraft o2 sensors. And i also did the walker exhaust all the way back.
A 2 sets of coils as well... motorcraft in there now. Had accel at one point
Struts and springs replaced with quick lift ranchos.
front wheel bearings - timken brand
front heater blend door motor
alternator - forget which one i used but was from local auto parts store
a few batteries - maybe 2 ? last was is agm from advanced auto
front upper and lower arms with ball joints
New wheels - original were steel and looking bad
painted side plastic with duplicolor bumper paint
neoprene seat covers.
regular diet of mobil 1 5w30 and wix filter
amsoil in rear diff
rear abs sensors
took plastic stuff out by oil filter... easier to change filter
and the front driver seat broke at hinge, got new used on from scrap yard
front caliper seized and replaced was bad too ... ugh finally okay
trans drop pan and filter too and transfer case
issues now ....
inefficient o2 code every now and then on bank 2 -- i just clear it for now. passed emissions
all the monitors were set
Some oil leaks but who cares
rear diff seal leak ... just fluid
rocker on driver side showing some rust
radiator support driver side rust.
front windows go up slow -- just hit tracks with some silicone spray
The only work done by me except the darn spark plugs and engine replacement and head. i shy away from ford plugs and rather pay someone else to do those.
I usually keep them until about 200k but i thought this one would be 300k because of the reman engine but i dont know. we will see.
I cannot afford a new expedition so i guess keep fixing this one. Then i will probably end up with one of cars pretending to be a suv. Honda passport? -- trans issues and timing belt and some other stuffKia telluride , way too new or many one of those ford broncos on ranger platform?
