G
Guest
Guest
Hi All,
Here's the story: Wife has a ‘99 2wd 4.6. Service engine light came on and vehicle also exhibited shuddering problems. Autozone did a computer check and stated that the engine light was EGR Valve and/or EGR flow related. We brought it to our mechanic who did a standard tune-up and replaced the EGR valve twice but was unable to get the engine light to turn off after FOUR trips .
Gave up on them after wasting the time and $ and brought it to a new mechanic who changed the transmission fluid and fuel filter (again). I asked if he extracted the fluid from the transmission, he described his process as removing and cleaning the pan, draining the fluid, and draining the fluid from the torque converter. He also informed us that #4 cylinder wire was bad and recommended replacing them all. He also wants to clean the fuel injectors.
Please note that I do not know much about these things and am literally using terminology from the mechanic, though a “cylinder wire” to me just sounds like a spark plug wire.
Current quote is $80 to replace EVP sensor, $100 for cylinder wires, $75 for the labor for that work, and $60 for the fuel injector cleaning. Already charged $140 for transmission flush and the “computer check.”
So finally to the questions:
Was the transmission “flush” service adequate? I’ve read some articles about a vacuuming process to properly flush the system, which apparently didn’t take place in this case.
What exactly is involved in “cleaning fuel injectors?”
And finally, if I get these remaining services performed will this likely resolve the problems we’re currently having with the vehicle?
Thank you for reading all this, and thank you ahead of time for your replies. I’ll be heading to Autozone tomorrow morning to talk about this stuff some more and get some alternative pricing.
Ryan
Ryan
