Low buzzing sounds like alarm clock
Blackwater
Maryland
I have a dull buzzing coming from the top hose off the intake that wraps around a connects to the the rear of the motor. This hose has a canister in the middle of the run. Sorry if I had my book on me Id be able to list what this is and what it is running to.
It buzzes under idle only. took a few days to track this down.
grantikal
orange county
i am experiencing a similar problem and i have not found the culprit but i did get a few leads. Autozone clerk an ex ford mechanic took a listen and thought it could be the idle pulleys i have the 5.4 so it has one on each side or a vacuum hose. as for now i am still not sure maybe I will get to the bottom of it when i replace the drive belt sometime this week.
thePUNISHER
ct
the Pcv hose? to the passenger valve cover? its probably the pcv valve. ford revised it for this issue. replace it.....
grantikal
orange county
did some research at autozone:
some possibilities:
Symptom: Hum/Buzz/Whine
When: Idling or Driving
Where: Engine Compartment
Priority Action Part Type Cause
1 Inspect Belt Incorrectly Routed, Adjusted(Tensioned), Missing or Worn Drive Belt(s).
2 Inspect Fan Clutch Loose, Faulty or Worn Out Fan Clutch.
3 Inspect A/C Compressor&Clutch Damaged or Faulty A/C Compressor and/or Clutch, Low Oil Level.
4 Inspect A/C Compressor Damaged or Faulty A/C Temperature Switch Cycling Compressor On and Off Too RAPIDLY, Low Oil Level.
5 Inspect A/C Temperature Switch Damaged or Faulty A/C Temperature Switch Cycling Compressor On and Off Too RAPIDLY, Low Oil Level.
6 Inspect A/C Hose Assembly Metal A/C Lines VIBRATING AGAINST Other Components Under The Hood, Faulty Blower Motor BushingS.
