I have a 1997 Ford Expedition 5.4L 4x4 with 150,000 miles on it. I was having some misfire issues which lead to replacement of my injectors and coils. After I replaced the injectors the truck wouldn't start. It would crank and crank then back fire. Finally tried starting fluid and it fired up but ran rough. Thought it could be air in the fuel rail and didn't think much of it. It is still idling rough, I am getting really poor fuel economy (around 5mpg on a good week) and it has lots of troubles getting up to speed and maintaing it. When on the freeway in order to maintain about 65mph it sits at 4000rpm and the speed still drops. I have checked vacuum lines and used a vacuum pump to test them. All were ok, replaced the elbow on the back of the intake manifold as it broke when trying to remove it. There was a small vacuum line between the firewall and the battery on the pasenger side that was broken and I fixed that.
Thought it could be the mass air flow sensor so I checked that and I was getting power to it, and I replaced the sensor but still no luck. I have also replaced the o2 sensor on the pasenger side because it threw a code for the circuit being too slow. As of right now, I am getting P0171, P0174, and P1131 which are all related to the truck running too lean. I have removed the cats and it smells like raw fuel coming out of the tail pipe. I have ran fuel pressure checks and they are all between the specified ranges. I have tried spraying starter fluid and listening for an increase in rpms but no luck. I have tried spraying water from a squirt bottle to see if steam comes out of the tail pipe or the motor bogs down and no luck either.
I had to replace the head gaskets prior to all of this and replaced the plenum and intake gasket at the same time. It ran fine after that except for the misfire but I am stumped on where to go from here. Why would new injectors and ignition coils make it run worse?
Any help will be very much appreciated.
Thanks,
Matt
Thanks,
Matt
