1955moose
- Joined
- Nov 23, 2014
- Posts
- 5,981
- Reaction score
- 1,338
As far as your dimmer/thumb wheel switch, you can pull plug, and switch, much easier that way, connect leads of ohm meter using helper alligator clips, set ohm meter on highest setting, rotate thumb wheel, observe meter. At brightest point on switch your reading should be at its highest, probably above 10k ohms, as you dim thumb wheel down, the ohms should drop down smoothly. It's basically like a volume control, on any electronics device, designed to raise and lower current. With power and ground hooked to it, at its highest would be 12volts, dropping down as you rotate thumb wheel. Theirs videos on you tube showing how. Report what you find. Any time you convert air springs to coil spring's, you've got to tell the computer. You were lucky, you just had to flip a switch!
