Noise from engine bay
I agree with the other guys it sounds like you've got to get dirty. In your video you spun the alternator, it sounded fine. What about the other pulleys ie belt tensioner, smog pump, power steering?
2004XLT
CT
I'm going with timing chain tensioners if it's louder in the front. What's your mileage at?
X
xfiles67
Va
One pulley was a bit wobbly with a squeal, just to the left and up from the oil filter, just to the left of the power steering pump.
142+ on the clock.
Before you pull apart timing cover remove belt, and spin all pulleys. Had a member about 6 months back had a bad belt tensioner. Sounded like a skate. If all are quiet, time to pull cover. Don't drive anymore!
X
xfiles67
Va
All pulleys have been spun, just 1 with a chirp, rattle still there with engine running without belt.
Videos on first page.
Well looks like your pulling timing cover!
X
xfiles67
Va
So that begs the next question, with 142+ on the clock if one is going to do a timing set job it almost seems dumb not to replace the oil pump right?
Temple, Georgia
Don't worry about the oil pump at this point unless you have low oil pressure. If you discover parts of the chain guides are missing, they always end up in the oil pan. At that point you need to drop the pan and get them out. If you don't you risk the chance of blocking the pickup tube. You don't want that to happen.
X
xfiles67
Va
So not at all looking forward to this I've been checking out the local shops, out of 3 I checked with only 1 was interested in the job, at almost $1800......
Any of our members in Virginia want to give xfiles67 a hand!
