and checked the air pressure in your tires.And also cleaned the windshield Weather Premitting
Dip stick? i have to stand on a stool to reach my '17. The '07 was right there.
275K miles? Just use the cheapest oil you can find. 2007 spec was 0W-20. I'd use 10W-30 or 40. The 20-grade was for fuel economy.
-- Chuc
And checked your tire pressures while pumping your gas.
FIXED! The oil gasket was bad causing the leak. Purchased a new one from Amazon.
Thanks for the help!
What gasket?FIXED! The oil gasket was bad causing the leak. Purchased a new one from Amazon.
What gasket?
