rtbrjason
Well after a bit more research, and running across this thread (Lightning Headlight MH1 Projector Retrofit guide!!! - Ford F150 Forum - Community of Ford Truck Fans), I've decided I will likely go with the Morimoto mini H1's, which apparently won't require any cutting of the buckets. I actually have the same aftermarket lenses he used already.
I'm going to skip the rest of their kit for now. I'll probably do a DDM tuning HID set as I've had good luck with them in the past. I've also recently setup a 40amp relay to power the HIDs for this last set to try to get rid of some flickering issues, so I'll just grab the projectors and shrouds from TRF, probably sans halo.
