03ExFX4
Recently purchased our 2003 Expedition XLT Fx4 5.4 about a month ago. During the test drives, everything checked out and did not come across and A/C issues or other issues for that matter. Truck was solid.
One day on a drive back home, I noticed the Rear A/C was blowing warm. Did some research and boiled down to two sources..
Either the Temp Blend Door is bad or Rear Air Expansion Valve is clogged.
I let the truck run for a bit and checked the Freon line going the the rear unit and the line was cold. Checked the rear A/C and it was cold. Rear A/C Blend Door does not make any noise and have not verified that it is actuating or not.
Air was good for a couple weeks and them became more temperamental. I have found that in the mornings and at night the rear air will blow cool/cold. However in the Arizona Summer Heat during the day, it will blow warm/hot, although sometimes cool/cold. Taken it to the dealer and the they provided same suggestions that it could be either the blend door or the expansion valve. I am not totally sold on those being the culprits and would like to see what others might think on the issue.
Did some searches and only came across issues where the Rear Air Blend Door was clicking or that the Rear Air was warm/hot all of the time. Could not dig up any temperamental issues.
Anyone else encountered a similar issue?
Possible thoughts?
Any advice/opinions are much appreciated.
Thanks,
David
Possible thoughts?
Thanks,
David
