I hit the fill plug with just under 2 quarts and the friction modifier.
A quart is a touch over 33 oz. so the friction modifier which is actually a 4oz. bottle is about .12 of a quart.
So 2 quarts of oil plus 4oz of friction modifier is give or take 2.12 quarts. Plus you are never going to get all the old fluid out so buying 3 quarts is a waste.
Put one quart of gear oil in, then the friction, modifier, then top off with the second quart.
That way you get all the friction modifier in there.
The gears mix up the fluid so well you could put it in first if you want.
But I would not put it in last.
