Rear wiper fluid discharge mess
Clearwater
The wiper fluid basically just oozes out all over the rear hatch and step pad. The wiper arm & blade works but hardly gets any of it onto the window
I believe it should spray down, maybe like a mist onto the rear windshield.
Is this problem common? The front wipers work fine btw.
Suggestions? Thank you
Hamfisted
Ft Lauderdale
Clean out the rear nozzle ? Replace the whole third brake light assembly with an LED unit ?
2005ExpeditionEB
Clearwater
Ive done both. I changed the brake light assembly about 3 years ago. That didnt change it for the better. Plenty of wiper fluid comes out, it seems too much. So i guess that means it is not a leak or clogged somewhere
2005ExpeditionEB
Clearwater
This is a pic of what i was trying to describe last night. Plenty of pressure and fluid comes out but it doesnt spray at all. Just shoots out straight down to the license plate and bumper
Hamfisted
Ft Lauderdale
How long have you owned the Expy ? Because that's a normal flow. It doesn't "spray" out like the front washer nozzles do.
rjtehan
