Yes, I just got one installed about town months ago. The Ford alarm with the keyless entry/Remote start/alarm is the "Gold" alarm from ford. I was able to get it from my local dealer for about $275 with the PATS controller. I then went to the shop that my dealer contracts out to for the install. They charged me $150 for the install. It works out great. My wife loves it. I even got the shop to install a glass breakage sensor into the kit for added protection. The Gold key fob has 6 buttons (lock/unlock/panic/start/aux1/aux2). I used the aux buttons to turn on my lights and to open my power hatch.
Here is the info I got from another board. I am just reposting as I do not want to link to another board because I am not sure if it is frowned upon.
Here are the 3 different Ford systems offered with the part numbers and a picture of the remote fob that comes with it (NOTE: These are 2009 part numbers only, the part numbers changed for the 2010 systems because of the new My-Key feature).
Remote Start only (basic system) Part Number: 7W3Z-19G364-AA
https://assets.forddirect.fordvehicles.com/assets/GFA/GFAMEDIMG/8801EF28-D99F-2297-24AD-66DA24AD66DA.jpg
Remote Start only, Bi-Directional (2-way) Part Number: 9C3Z-19G364-A
https://assets.forddirect.fordvehicles.com/assets/GFA/GFAMEDIMG/8801EF28-655F-F8C0-19F1-A05C19F1A05C.jpg
Remote Start, With Keyless Entry & Alarm Part Number (gold system): 7L3Z-19G364-AA
https://assets.forddirect.fordvehicles.com/assets/GFA/GFAMEDIMG/8801EF28-2937-FAF5-19F2-850019F28500.jpg
For the first two remote start systems, you would have to carry your factory keyless entry fob with you too. I think the first one is the one you get as the factory invoiced accessory remote start system if you order your truck with it. The second one is actually a 2-way type system, the button flashes green and the keyfob beeps to confirm that the truck started. The third system includes the alarm, and it replaces your factory keyless fob since the new fob does control keyless entry and remote start all in one fob. The extra 1 and 2 buttons on the fob are pretty much useless for our trucks. You could turn the alarm feature off if you want (if you don't like alarms), but at least then you would still have everything all in one key fob rather than having to carry 2 fobs around.
The 3 systems cost between $200 and $230 plus shipping through an online discount Ford parts dealer. Sometimes you can find them slightly cheaper on Ebay. I lucked out and I think I bought my 6-button system for around $150 or so on Ebay.
For either system, you also need the Ford PATS Interface/bypass kit, the part number is 8L3Z-19G365-BA. It costs around $25 plus shipping. You just need your 2 master keys to program this kit. You don't have to take your truck to the dealer to program the PATS kit or the remote start/alarm system.
The first two remote start only systems above actually install pretty easy now, they come with a plug-in harness that plugs directly into our trucks. Then there’s only about 6 wires or so left that you have to splice-in yourself. The 6-button remote start with alarm system does not come with any type of plug-in harness, so you have to tap/splice all of the necessary wires (about 16 or so total). Most of the wires you tap into are along the steering column and driver's side kick panel/door sill, but there's also 1 or 2 wires that you tap into at the passenger side kick panel at the smart junction box (SJB).
I hope this helps you.
