Speed sensor
whtbronco
Winchester, VA
Sure they fail occasionally. We'd need a bit more info to help though.
Two have failed on my sons 2000 Ranger over the 10yrs we've had it, the first was failed when we bought it. I think the trans mounted speed sensors fail less often compared to the axle mounted ones, like the Ranger.
whtbronco
Winchester, VA
What symptoms have you seen? Any DTC's?
If you have a rear diff mounted speed sensor you might be able to pull it out and clean it and resolve the issue? I've never had that help, but I change gear oil frequently. I suspect if it might if the gear oil is not changed often or there is significant wear in the differential leaving metal and other crud on the sensor.
johnjohn205
