Startup Rattle
1955moose
Sounds like you hit upon the right shop. Unfortunately he's right about the 2nd and 3rd gen 5.4's. If you've read the forum, some members have great luck, others not so much. If your Suv is otherwise in good condition, it should be the smart money way to go.
J
JediKnight2
NC
Can someone elaborate on the oil pump and firmware/software update?
Andy J
San Jacinto, CA
Sounds similar to what my navigator was doing. I am certain that you have a timing chain tensioner thats going bad and taking a few seconds to pump up like what was mentioned earlier. Im not sure if its an option on the 3v engines but on the 2v and 4v engines some came with cast iron timing tensioners and others had the plastic ones. The iron ones were nice because they had a small ratcheting arm on them that would extend out to the back of the tensioning arms and lock into place keeping tension on the chains even when there was no oil pressure. This would stop the rattling on startup. The plastic ones have a spring inside of them thats supossed to do the same thing but they rarely work as well as the iron ones with ratchets. See if you can find a set of the iron ones for your engine.
1955moose
The Melling part #s are m340 of if your going witha higher pressure pump 10340 I agree get the metal guides, and best cam advancers you can. Now is the time to upgrade and do it once and right!
If you have a 3 valve you must change your oil often, truth is you need to with any modern engine as they all can have oiling problems. Modern engines with variable cam timing have very small oil passages that are prone to sludging. GMs have issues with AFM sludging and ruining motors it’s not a ford thing.
rjdelp7
2000 XLT
NY
There may be nothing wrong. These motors need correct 5w20 or 5w30. Running too heavy starves the the top end. The cam follwers(correct name), can fall off at high RPMs. The motor will have a code and miss. If the the follower is off, it can be put back on. Plenty of vids on youtube.
johnboneske
Ohio
For what I have found, ALL 5.4 2 valves(I dont know anything about the 3 valve engines) built after 1999 have plastic tensioners in them.
red-russian1
Minnesota
How heavy is too heavy? When we first bought our 2005 Expedition about a year-and-a-half ago with 104,000 miles on it, it ran fine until I switched all of the fluids over to Amsoil oil. Within a month, I happen to check the oil one day and it was 2 quarts low. I've heard some horror stories about running synthetic in a used engine so I switched back to Mobil 5000. The engine stopped using oil but within about another month, the engine developed the dreaded dieseling issue, which it has to this state yet. I changed out the VCT solenoids and switched over to 10W-30 but the engine still Knocks. Should I switch back to 5W-30 again?
johnboneske
Ohio
Hard to believe that Amsoil cause the problem... Did you change viscosity when you switched to Amsoil? I used to ue it for years in everything I owned. My pockets arent as deep now and only use Mobile 1
rjdelp7
2000 XLT
NY
If a cam follower fell off, you would have a blinking Service light. Running 2 qts low, may starve top end, if you rev it 4-5K. I own a Lincoln 4.6l 32V DOHC. It had a start up rattle, with Motorcraft full Synthetic 5W20 and FL820. I switched to Mobil 1 and a XG2 ultra syn filter and rattle went away. Amsoil is not API approved and does not have starburst seal on bottle. That is why, it is not sold in stores. Amsoil claims they do want to pay for API fees. Amsoil is very pricey and sold through "authorized" dealers(aka, people selling out there home). Some say its is all clever marketing. If it was a truly a great product, it would be on the shelf, next to every other brand.Amsoil OE is now API approved and sold in some stores. It will not void warranties.
