tow package
getnbzi
maryland
hi I was just looking at the list of options on my 2017 limited and it says Class IV towing equipment hitch harness and and brake controller is that considered the package or is the more that there needs to be I have about 3500 lb bass boat and wondering what else I might need
thnx
Sgt Darkness
East Tennessee
If you have the towing package, the rear end gears would be 3.73 also. The class IV trailer tow package on the window sticker would also indicate an updated tow package. Even if you didn’t have the tow package, a 3,500 boat would be no problem to tow. I recently towed a 18,000 pound house boat with my Silverado with no problems, even though it was only a five mile tow I was a tad nervous to say the least as the houseboat was at least three times the size of my truck.....good luck!!
Sgt Darkness
East Tennessee
HD Tow does not include the 3.73 axles, they're a separate option. Used to be included but not in the 2017 models.
-- Chuck
On the 18s the 3.73 gears are part of the HD Tow package per the window stickers. Didn’t know on the 17s or earlier models you could get other rear gear options with the HD tow package......thanks for the information, appreciate it.....
coolzzy
Idaho
I believe for 15+ that ALL EL models got the 3.73 gears regardless of having HD tow or not. On the short wheelbase models, 3.31 was an available option and pretty standard fair from what I found when shopping for my EL.
On 07-14’ the 3.73s came on 4WD models I believe 3.31s were only on 4x2.
chuck s
I order all my SUVs with HD tow starting with my '02 Explorer. It's like $300 from the factory.
The '02 Explorer and the '07 Expedition had the 3.73LS axles, the '17 Expedition has 3.31. The '17 tows my travel trailer much better than the previous two.
-- Chuck
cmiles97
Tampa, FL
I have a non tow package EL XLT. I added a non ford brake controller and 7 pin connector to replace the 4pin. I pull a 5000+ utility trailer a few times a year with no problems. MY EL has the 3.73 gears.
To answer your question, the HD tow package also has a higher capacity radiator. transmission cooler, etc. It's all listed on this brochure.
https://www.ford.com/cmslibs/conten...df/brochures/17RV&TT_Ford_Expedition_Sep7.pdf
Eagle 71
Nebraska
My ’13 is a 4x4 with the 3.31 final drive ratio and the equipment group 203A, which included the “Heavy Duty Trailer Tow” package. For info, my Expy’s rear axle does not have the limited slip differential.
