GaExpedition
Been having on and off issues with the right turn/parking light circuit on my 2000 expy. First, it was intermittently blowing the fuse under the hood. Now it's to the point of not working at all even after replacing the fuse. I have also checked the fuses inside the cab and all are fine. After doing a few searches here, I read that there should be 2 wiring harness connections under the truck. I know one is at the back where the 7 way plug connects, but I can't find the other so I can track down where the short may be with my multimeter. Anyone know where it's located? If not, will it hurt if I bypass that particular wire, and just run one from the right rear turn signal itself to the 7 way plug?
