Transmission searching for the correct gear
Tampa Expedition
Tampa
just moved from Tampa to Birmingham. In Birmingham there are more hills that I am driving and the truck can’t find the right gear at slower speeds. Does any one know if there is a software update, as my expedition was one on the first with 10 speed transmission?
Going_Going_Gone
Phoenix
Perhaps disconnecting the battery long enough to erase your previous "shift memory" might help. Then the computer will "learn" your new driving parameters. If that won't work, I got nothing.
AAOO
Use forscan to reset the transmission adaptions.
Deadman
Wisconsin
I'm assuming its a non tow package vehicle with highway gears In it that are pretty hard for it to push at slower speeds.
99WhiteC5Coupe
Did you contact a Ford dealer with your VIN to determine if there are any transmission updates available?
duneslider
Utah
Like mentioned, I would check with a ford dealer. I thought I read somewhere that there was an update that seemed to change the transmission shifting. I have the lower axle ratio but I do not seem to have any transmission hunting issues. If it is doing it I don't know it because it shifts so smooth.
