SkyJumper
Well relatively speaking plugs are not wet when pulled if everything is functioning as it should. If you have oil build up on the plug then you know what that means. If you are wet with fuel, then you are not burning efficiently. During the combustion stroke the burn should be hot enough to burn all wetness from fuel.
You can take a multimetr to the pgtails to see what your reading are. But based on your words as this happened after you replaced that plug alone, then it is something that you did that day that is causing it. Either you have a pigtail inner contact screwed up, or a spliced wire to the injector, or a bad seated pigtail not making contact, or a injector not seated properly, or air getting into the injector feed line. Or your plug is not seated allowing blowby on the combustion stroke.
I mean there is so many scenarios that it is going to bee hard for anyone to pinpoint it as most if not all possibilities have been mentioned.
Only thing I can keep suggestiong is to do a psi check at the fuel rail, a compression check at the cylinders and recheck everything in the general area that you could of cut, unplugged or shorted out.
