gordizmom
Hi everyone. This is a bit long but I need your opinions on this issue.
I have a 2000 Expedition, Eddie Bauer Edition. Bought it used years ago. It's a good running vehicle.
Before I moved from Florida in the Spring of 2019 I had a triple A battery installed in my truck and was under warranty for a year. The Fall comes along and my truck began having starting issues. I have AAA so I had the local garage come over and jump start it. I used up the rest of my service calls on this so I had my truck tested to see what the problem was. A diagnostic machine was put on it (or so I was told), fuses were checked, etc. and I was told that 'something' was pulling from the battery but nothing was found. ~sigh~
I drove to the triple A garage in the nearby city and found that the battery was bad. I'm sure it happens. Battery switched out for a brand new one, this one under warranty also.
More problems. Truck wouldn't start, everything dead. This was the beginning of 2020 so I had four service calls I could use and I used two. I didn't want to use any more calls so I purchased a small jump starter device called a Gooloo. It works very very well and I had to use it each and every time I needed to drive my truck. It's bigger than an iPhone but smaller than a tablet. Great little device.
Last week I decided to take my truck back to AAA and find out what exactly is going on with my truck. I drove 40 minutes on the Interstate in the rain, stayed at the place from 10 until 3 pm.
I also had an oil change done while I was there. This should not have taken so long but it did.
The mechanic charged the battery to its full capacity then let it drain. He also drove my truck around which I don't understand why but he did. After a very long and boring wait I took a walk to the grocery store and bought something to eat. I was told that the battery "wouldn't die" so the mechanic had to charge it up once again, let it drain and drive it around again. I was totally confused but whatever. I just wanted them to replace the battery and let me go home.
After sitting there for another seemingly forever hour I was told that the battery "finally died" and they replaced the battery with a new one. ~another sigh~
It was explained to me by the guy at the counter who was actually there last year when I took my truck in that I needed to drive my truck more often. I only leave my house once a week and where I go is about four miles to and from. He said that if I'm not going to drive much I should either disconnect the terminals or put a trickle charger on the battery.
I asked him to explain to me how is a battery able to drain if it's just sitting. He told me but it sounded confusing. I don't know much about vehicles.
I really do not understand how a battery loses power just by sitting and being connected to the vehicle. Oh and I was also told that they (AAA) would not replace another battery. This is something I intend to take up with the corporate office because their batteries are under warranty for a year.
I would appreciate any opinions, thoughts and advise any of you can offer. By the way, I live in South Carolina and it gets down below freezing in the winter.
