Hey, I have an expedition 99, I had the issue with the torq bolts getting loose so the shifter not responding right, was coming home and it got to the point that I couldn't get it to start (I should have tightened them but I'm a bigger guy and put it off). Had to have it towed home, next day I tightened them down and the vehicle still will not start. Doing research online and in my hanes manual, I thought it was my neutral safety switch. When it was loose if I pushed up on the shift lever it would start, but then it would start just fine 90% of the time. I switched that and it didn't fix it, going through my hanes book they said it could be the ignition relay or ignition switch...switch both of those. Saying it could be my starter but really don't want to pull that to test if I can avoid it. All the connections seem to be solid, not sure where to go next unless it is pulling the starter to get tested. If that's not the problem however..what else can you guys suggest?
Everything powers on, when you turn the key it just doesn't do anything, like it's not in park. Won't start in park or neutral.
Thanks
Thanks
