Wtf Rattle noise is this???
Habbibie
Is it Christmas yet?
Chicago
hey guys kinda need your help on this, this rattle noise appeared about a week ago and it sounds like a loose screw is bouncing around inside the cylinder, identical sound to if you take a rock and put it in an empty tin can and shake it.
This noise appears on cold starts and it stays there for a few minutes until it reaches optimal operating temperature.
It is an inconsistent sound (it doesn't have a rhythm)
I haven't been able to pin point exactly where it's coming from but it's loud enough that you can hear it from about 100 feet away.
Engine oil is full
5w-20 full syn. (only burns a quart every 3k miles)
Coolant is still full, it's not mixing.
Drives fine (though I feel a little lack of torque on take offs now)
No CEL or any symptoms so far just the noise.
I couldnt find a single video on YouTube that closely resembles this noise and I'm kinda on the fence on what this might be...
Any clues?
This is not a cam phaser tick as I have that consistent tick cold or hot and it's there right beside this rattle noise on cold starts
Habbibie
Habbibie
Chicago
Yea I tried taking one after posting this thread but the noise wasn't there since the truck wasn't fully cooled down like it would overnight. I'll try again tonight.
Habbibie
Habbibie
Chicago
Ehh OBDII port isn't working now... I swear I've never seen a car with more problems that this ford pile of crap
Edit: seeing I don't have an owners manual would any of you 2nd gen owners happen to know which fuse I should be looking for (fuse #?)
Habbibie
Habbibie
Chicago
Never mind guys I found the blown fuse, I don't have a replacement 20A fuse to switch it with but for testing to be sure it's the fuse I put a 10A momentarily and that activated my scanner so that's out of the way... Now back to the chain slapping subject. I'll try to get a video tonight I just gotta let it cool down for a few hours.
Bedrck47
Elizebethtown, PA
Habbibe
Go to owner.ford.com and you can download a copy of the owners manual
Also you need to be careful as to what you plug into the lighter circuit as the OBD connection port is on the same fuse.
Habbibie
Habbibie
Chicago
Yea I shorted it by placing an all metal 3/8" impact socket adapter inside it.
On with that I'll download the manual tonight at home thank you for that.
Habbibie
Habbibie
Chicago
Any idea guys on what this noise might be? It's loudest in the front of the engine more so near the location of the bank 1 VCT solenoid (passenger side).
sharprd65
