xsalsaraynex
Hey ford expy owners,
I need some help. And I'm not sure if it's been asked but it probably has. Searching was just taking too long for me.
The vehicle:
2003 ford expedition eddie bauer with the sub.
The problem :
I installed a jvc av71bt. Using a harness, there was no wire to wire work done other than the radio harness to the aftermarket harness which plugs into the factory plugs. The radio worked fine for a few days and then suddenly failed to turn on period.
I checked fuse 7, 22 and 31. None of those fuses were blown - I tested with a DMM and they had continuity.
I found out that removing fuse 31 and re inserting fixes the power problem and the radio turns back on for another couple days.
Following a couple days the same situation happens - no 12v.
Anyone experience this?
The vehicle:
The problem :
