Rear cat delete
JTKustoms
Boston
I know this has been discussed before and a few of you guys have done it but I'm looking to get a few answers. I went to the shop that did my exhaust a few years ago and asked about either deleting the rear cats or putting a basic cutout between the front and rear cats on each side. I was told it would deff give me a check engine light by deleting and that there is not enough room between the front and rear cats for a cutout. I'm just trying to see what modifications, if any, would be required to delete the rears without any engine light issues. Any help would be appreciated because i wanna do it soon
WSS1
So. Cal
Can a good custom tuner write up a tune and eliminate the 02 sensors or whatever it is that will throw the code?
panda24619
San Diego
it wont throw any codes. plenty of people on here have done it with out one problem. except bad mpg, the sound of the engine is so good that they cant keep the lead foot off the skinny pedal. but in theory your mpg should increase. i would do it, but cali dosent allow it.
JTKustoms
JTKustoms
Boston
So panda from what I understand there is an o2 sensor before the first cat then another after the second cat, and by deleting the second cat I won't have any issues with the o2 noticing a missing converter?
Newport News, VA
i remember being given the answer that it depends on where the 2nd o2 sensor is placed on the rear cat...i believe if the sensor is on the front of the rear cat we're good...if on the rear of the cat...CEL...when i get my exhaust done again i am looking at doing the delete as well...search rear cat delete or similar early 2011...i think thats when all that talk went down...they may have made a sticky...idk...should be a sticky though...common question
toms89
technical advisor
MD
The front o2's are critical for tuning. When the ecu goes into closed loop it is the front 02's that the ecu used to adjust the air/fuel ratio. These are ahead of the cats because the ecu needs unmodified air fuel readings from the motor to properly tune. The rear O2's are strictly for monitoring the effectiveness of the cats and can be turned off in tune as said. You may need a custom programmer to do so.
As panda said many here have deleted the rear cats with no cel's. Apparantly the front cats run clean enough that the ecu believe its with-in limits.
tallsville
LA
if i remember correctly some have welded bungs on the pipe to(for lack of a better phrase) pull the rear o2 out of airstream.
WSS1
So. Cal
I have never understood the reasoning with cali, if I am getting better mpg, isn't that less pollution? I just did a cat on a jeep for a friend and found that we are very special! It had to ba a certain cat (1 state as opposed to a 49 state). Ahhh, the republic of California.
LOL
WSS1
tallsville
LA
yep. funny thing is spintech makes a hiflow cat that cant be used in the state that its made in. Thank CARB for the restrictions. but also remember we have 12%(1% in L.A. alone) of the US population in CA. alot more people and cars so have to offset the amount.
Thermo
technical advisor
Better mileage does not mean less pollutants. Do some looking around on the internet for "Mythbusters Bike Vs. Car". They compared a few different vehicles to each other and then also compared a few motorcycles to each other along with comparing a car to a bike. Obviously, the motorcycle had much better mileage, which using your thought process, would mean that you emitted less pollutants. What they discovered was that even using a "modern day motorcycle with low displacement" (use a 2012 250 CC bike as I recall) with a custom wind faring to help with its aerodynamics to make it the "most green it could be", the emissions coming off of the bike were around 10 times as much as a standard car. The bigger displacement motors actually can burn the fuel more completely, resulting in lower overall emissions since the fuel can spend more time in the fuel chamber (you never see a V16 train locomotive up at 10,000 RPM).
So, you can not relate mileage and emissions to each other. There are far more factors into the emissions than just the one.
toms89
technical advisor
MD
Plus emissions test measures the quality of the exhaust not quantity. Didnt see the mythbusters episode but assume they somehow took that into account.
Jason_CPAPS
Harrisburg PA
you will have to add spacers from what i've been told which are spark plug non foulers. You will have to drill the one end out so that the o2 will fit. Depending on state emissions if they put a sniffer in the exhaust it will still fail even without a cel
JTKustoms
JTKustoms
Boston
Thanks for the input, I'll go to a different exhaust place one of the next few days and see what they say. And about emissions, I also saw a video comparing a leaf blower to a modern pickup (might've been a f150) and the truck actually had lower and cleaner emissions
JTKustoms
JTKustoms
Boston
Well I went to another exhaust shop today and got to look at it for myself, seems like the first cat on each side is kinda small and the rear ones are the bigger of the two. And the o2 sensors are behind each of the rears. So I know that it has been done before, but im still hesitant because i really don't wanna deal with an engine light after paying to have them chopped off. And the guy said $180 cash, does this seem reasonable? only reason I'm hesitant is because the cats have 189k miles on them so I'm not sure how efficient the front ones are and if they would clean things up enough on their own to prevent triggering a light
