mpsjr
I called Napa today and they said they can't get any of the Bosch pumps since they've all been discontinued. How long ago did you replace yours?
My receipt says 6/12/11. I don't know if it means anything but they are all listed on the site now.
Thats great glad you found one. Have you tried to siphon yours before. Mine has a screen on the neck somewhere that prevents you from shoving a hose down into the tank but I don't know if all years have this. I guess its an antitheft device.
I did alot of digging around and decided to go with NAPA's fuel pump which is actually a Carter. It should get here on Tuesday. Wanted to get a Motorcraft but there is no way I am gonna spend that much on a pump unless I really have to. Also, every auto parts store I talked to said that the Delphi brand is the actual replacement for our trucks. I dont know if this is correct or not. I noticed that mine did not have a brand on it. Did anyone have Motorcraft stamped on their original?
with Napa's pump assembly. Drove it today for about 100 miles with no engine light and no probs! I also replaced all the vaccum/vent hoses. Lesson learned to never use that brand again. Thank you all for you help and input!That's awesome, congrats. My new Motorcraft pump is working great as well, but my CEL (P0452) did come back on. I thought it might, considering this was the 3rd pump I've installed. I have yet to change the vacuum lines. Where did you get your hoses from? Did you have to order specific hoses, or just buy standard vacuum hose to fit? Did you just change the 3 that attach to the tank, or did you also replace the filler tube? I don't know where mine is leaking pressure, but I am almost positive it's one of the smaller hoses.
