well perhaps my search skills are not as refined as yours- I need to working on my keyboard jockey muscles.
You are correct, some of the bulbs are 194, the others are 37 (Ive a 1997 5.4). I actually only found one post that referred to the regular bulb numbers, and a slew of posts that explained how to do it. For most those would have been very helpful. The one post said something like 10 194s and 2 37. I found this inaccuratte for my 97. There are more like 12 194s and 7 or 8 37s.
I found the mystery (which created a new mystery) of why my CE stopped working. After pulling the cluster, the light was not there. The light was there recently.. as I had a bad coil and the CE was on... but... for some reason it was not there. The new mystery is- what happened tot he assembly?
So after replacing as many as I had bulbs for (I only bought 2 37s), it started making this annoying noise- 5 beeps, 3 second break, 5 beeps- all coming from under the passengar dash or floorboard area. Naturally I ASSumed I had done something wrong. Turns out, as the manual says, it was related to the airbag. I guess I did something to the bulb as I checked KOEO and no airbag light. Took it apart, again... and found it.
Now- hopefully this will help others. The previous owners pretty well trashed the truck before we got it- and ive slowly been trying to get it back to factory condition. Two of the lights were missing (in addition to the CE) and even had tape over them. In searching the major vendors for the bulb number, I found them a step shy of useless- I mean.. who would mean headlight bulb when searching for CE? I found the numbers and of course- they are pretty common and standard- for the bulb. My local NAPA had the bulb holders too- and both those and the bulbs were around a dollar- the other major labels it was... closer to 5.
Advise:
- Follow the instructions (search the forums) for details on pulling out the instrument cluster. Its not as hard as most commonly believe. Just be careful (the previous owner apparently yanked it and broke some of the clips)
- If you think you may ever consider upgrading the bulbs this would be the time to do it
- Pay attention to which bolts you pull from where. In my case, someone had done this before me- based on the missing bolts.
- Its not necessary to unplug the cluster, I could only get two of the pigtails out, the second time, I left them connnected
- make sure they are seated fully.
- reinstall everything as you took it out. You can even test while it is still out (but plugged in) just be very careful when doing so
