Fuse number for check engine light? (97 Exp 4X EB)
AuctionExp
Beaverton, OR
Hello Forum, 2nd post here.
I am wondering what the fuse number (and location) is for the CEL (check engine light).
I am asking because I cannot get the CEL light to come on, and now I cannot pass the state emission test.
I thought is was the #2 fuse (5a) under the dash. I replaced that fuse, but still no light. Is the CEL just connected to all of the other instrumentation? If so, it would give me a new direction to follow (bulb out on instrument panel).
Thanks for your help!
1997 Exp, 4X EB
FordandPolaris
Saint Cloud, MN
Ok we dont have emissions in my state so I am just curious. Do you mean that you cannot pass the test because you cannot prove the CEL comes on? Or is there an underlying problem that you think should be turning on the CEL but isn't, thereby causing the failed test?
If it is the latter one, go to an auto zone or Oreilly and they have OBDII scanner tools you can use for free. That will tell you if your truck is throwing codes even if the light isn't on.
Fastcat
St. louis, mo
Do u mean u cant get the scanner to read the computer? If so is it not powering up once u plug it in, or does it power up but when u try to read the codes it says no data link? If u have any one of those problems take everything out of the cigarette lighter and check fuses. there are 2 different fuses that run the scanner port thing. Lol. But i forgot which 2 they were
Sent from my PG06100 using Tapatalk 2
AuctionExp
AuctionExp
Beaverton, OR
Unfortunately, in Oregon they look for the CEL to display with koeo (Key On Engine Off). Even if there are no codes, if the light does not come on I fail the test.
I've checked the fuses under the dash, and even replaced known good fuses just be sure. It could be a burnt out bulb right? Maybe the CEL bulb is burnt out and all the other indicator bulbs are working.
I am just trying to eliminate the low hanging fruit before I pull the instrument panel.
FordandPolaris
Saint Cloud, MN
Its certainly possible. It says in the owners manual which fuses control what. I would think that the fuse that controls the CEL also controls the other warning lights, but I cannot say for sure. All I know is that mine works fine cause its always on! PM a member named Thermo with your question. He knows what he is talking about and may be able to give you information that I can't.
Thermo
technical advisor
Auction, your CEL bulb is burned out. If the fuse was blown for the CEL light, you would not be able to start the truck up as the ECM would not have power. Since you are into the instrument cluster, spend a few extra dollars and replace a lot of the other bulbs back there too. Once you start getting access to the instrument cluster, you will understand why I say what I say. take an afternoon and take it easy. Plan on spending about 3 hours on this "little" project.
JUST4FUN
Admin
Moderator Administrator
Il
i wonder if someone took a really small drill bit and drilled out the bulb
AuctionExp
AuctionExp
Beaverton, OR
Thanks for the advice everybody. I took my time, and replaced all the bulbs in the instrument panel.
Once I had everything back in place, I re-connected the battery and voila the CEL is working again.
As I noted, I did replace all the bulbs, but now I think I may have caused another problem. I was checking the bulbs, and when I used the 4WD selector switch, I was only able to get the 4x4 and Low Range lights to illuminate. When the selector switch is in 2WD or A4WD, there are no indicators on the dash.
This is my first Expedition, and I wanted to ask if there were supposed to be lights for the 2WD and/or the A4WD? Maybe because I was just in Park that the A4WD did not illuminate?
Thermo
technical advisor
Auction, yes, there is a light for the A4WD, but not for the 2WD position. It may be that you put the bulb in wrong or something else "simple" happened. Honestly, I would not worry about it. Unless you use the A4WD a lot, it is going to be tons more work than it is probably worth. For me, if that bulb burned out, I would never know. I am always going straight from 2WD to 4HI and only see the light come on as it is shifting through AWD.
mhowington
atlanta
bulb number for dash/cluster lights
does anyone happen to have the bulb number? I need to replace mine (and one of the illumination ones (left side) I suppose I could pull the dash and take the bulb with me, but thought perhaps... someone may already know what I need to get.
mhowington
atlanta
I am not sure what link your helpful reply refers to, but does this mysterious link have the bulb numbers? Pulling the dash isnt something I need instructions for- but I would rather have the right bulbs before I pulll it so replace them. Its really not all that hard- I had to pull it to replace the odomerter a few months ago- I should have just replaced them all then- I specifically need the check engine one- 194LL? no parts store seems to know and my "friendly local area ford dealer" is useless as always- unless I want a dash assembly LoL
mhowington
atlanta
oh, you can make a link in test, neat. That link displayed, after 4 pages of ads this:
"Because this job can be complicated for the inexperienced, I recommend investing in a Haynes Repair Manual. The one that covers this vehicle is #36059 and covers Ford Pick-ups and Expeditions from 1997 thru 2002. I recently replaced the bulbs in my instrument cluster, so I can attest that it is a pain to do this job. It is not very hard, but it takes some time. The bulbs are cheap, so I bought a box of ten and replaced them all, because as you know, if I just replaced the two that were bad, I'd be going back very soon to do the rest. The Haynes manual is very good. You have to remove the headlight switch first, and there is a trick to that. The illustrations are great to find the screws that hold things together. I followed the book step by step and found the help to be excellent. Good luck."
so I ask again, does anyone know which bulbs are needed? I assume there are two sets- one set for the illumination (speedo etc so you can see at night) and than a different one for the idiot lights. Perhaps they are the same- either way- I am not sure which ones I need to get. 194LL?
FordandPolaris
Saint Cloud, MN
http://www.amazon.com/Sylvania-Bulb-194-Pack-Bulbs/dp/B002PDRDOQ
My bad, I just do the googling for you. I did not read the link close enough to tell that the part # was referring to the Haynes Manual. All you have to do is type in your truck, and your part you are looking for, and a whole list of fun stuff pops up. That is the bulb you are looking for.
I find it hard that the Ford dealer could not tell you the part #. Call a different one maybe?
Here is another one: http://www.expeditionforum.com/f45/light-bulb-size-interior-exterior-7322/
But just in case my "helpful" links are too much for you, the bulb size is 194 according to about 5 minutes of research.
mhowington
atlanta
well perhaps my search skills are not as refined as yours- I need to working on my keyboard jockey muscles.
You are correct, some of the bulbs are 194, the others are 37 (Ive a 1997 5.4). I actually only found one post that referred to the regular bulb numbers, and a slew of posts that explained how to do it. For most those would have been very helpful. The one post said something like 10 194s and 2 37. I found this inaccuratte for my 97. There are more like 12 194s and 7 or 8 37s.
I found the mystery (which created a new mystery) of why my CE stopped working. After pulling the cluster, the light was not there. The light was there recently.. as I had a bad coil and the CE was on... but... for some reason it was not there. The new mystery is- what happened tot he assembly?
So after replacing as many as I had bulbs for (I only bought 2 37s), it started making this annoying noise- 5 beeps, 3 second break, 5 beeps- all coming from under the passengar dash or floorboard area. Naturally I ASSumed I had done something wrong. Turns out, as the manual says, it was related to the airbag. I guess I did something to the bulb as I checked KOEO and no airbag light. Took it apart, again... and found it.
Now- hopefully this will help others. The previous owners pretty well trashed the truck before we got it- and ive slowly been trying to get it back to factory condition. Two of the lights were missing (in addition to the CE) and even had tape over them. In searching the major vendors for the bulb number, I found them a step shy of useless- I mean.. who would mean headlight bulb when searching for CE? I found the numbers and of course- they are pretty common and standard- for the bulb. My local NAPA had the bulb holders too- and both those and the bulbs were around a dollar- the other major labels it was... closer to 5.
Advise:
- Follow the instructions (search the forums) for details on pulling out the instrument cluster. Its not as hard as most commonly believe. Just be careful (the previous owner apparently yanked it and broke some of the clips)
- If you think you may ever consider upgrading the bulbs this would be the time to do it
- Pay attention to which bolts you pull from where. In my case, someone had done this before me- based on the missing bolts.
- Its not necessary to unplug the cluster, I could only get two of the pigtails out, the second time, I left them connnected
- make sure they are seated fully.
- reinstall everything as you took it out. You can even test while it is still out (but plugged in) just be very careful when doing so
