Lonesome
I'm have problems with my front and rear heat. It only gets warm. I've flushed the system and core's,changed the tstat, burped the system and even took the dash out check the blend door and a motor for it. Have hot water going in and out of cores but only warm heat. The higher I try the fan speed up the cooler the air gets. It's an 01 E.B. with E.T.C. Is there anything else I can check before I take it to the shop and spend way to much to have this fixed. Any help will be great!!!!!!!!!
