HID conversion
xb58
picked up the HID conversion kit from "mydepot" where you guys recommended, but am having issues with it.
has anyone tried the kit with an 03+ expedition? installed everything correctly im sure (since its a pretty easy install) but absolutely nothing happens... btw the 9006 kit does not come with a relay, so its extremely easy plug and play
X
xb58
Originally posted by 4x4Dude
What issues are you having? you should take some pictures or video of your issue.
its not working at all, absolutely nothing happens, highs and fogs still work, but nothing with the lows
AvroAero
Toronto, Ontario
Did the ballasts have any kind of "broken glass" in them when you got them? If so they're screwed.
Do they fire?
4x4Dude
Scottsdale AZ
if you know for sure you have everything hooked up right...you could send them back and they should send you a replacement if i'm not mistaken
X
xb58
Do they fire?
no odd sounds, and no they dont fire... they do nothing at all, has to be soemthing im doing wrong
4x4Dude
Scottsdale AZ
what are you plugging in to the wire to give it power? it should be connecting to the original wire for your headlights. it looks like you have something on the unit plugging into itself and it shouldnt be like that.
4x4Dude
Scottsdale AZ
i cant remember exactly it was a while ago i did it and i was half drunk lol so my memory is a little foggy
X
xb58
the loose plug just above the bulb hooks into the plug for power.. heres the direction, hard to see i know
http://i79.photobucket.com/albums/j135/xb5869/xb/2fc4f7e1.jpg
4x4Dude
Scottsdale AZ
i would normally say maybe one is defaulty, but since both aren't working, there is something that we are missing.
AvroAero
Toronto, Ontario
Get a 12 volt battery and use wires to connect the termials to the plug above the bulb in the picture. See what happens.
X
xb58
blue and black wires... blue positive?
X
xb58
ok, i hooked one up directly to the battery and it worked (btw: black is positive) lol
so what does this mean? that I need a relay probably?
X
xb58
ok, i got it figured out... there were clips throughout the kit just like stock where you can only connect the wires one way (the little clips click into the "fishhook" notch thingy) well the wires must have been backwards (figured that out when i saw that black was positive hooking up directly to the battery) so i broke the clips off and hooked the up "backwards"
light disbursment on with the stock headlamp sux, and I cant find the adjustment... where it says it is in the owners manual is wrong (verified by members of this forum) so I guess i need to full with that in the daylight and try and find a decent pair of projectors....
thanks for the help guys
4x4Dude
Scottsdale AZ
only thing that sucks now about getting a pair of projector headlights...you have to make sure that the new headlights use the same bulb as the ones you bought, or you have to buy a whole new hid kit :(
Congrats on getting them working...i can guarentee you though, you'll see loads difference if you get the aftermarket projectors
X
xb58
are projectors bulb specific, like different ones for hid than halogen?
now i need to find a set that work good, but dont look like the ones at the local ricer convention
No members online now.
Landsbutter
