The hose replacement took me less than 2 hours. (There were interruptions by the offspring) Overall, it went well with the added bonus of WAY better performance than anticipated. I'm posting a link to a youtube video that helps in planning for this adventure.
https://www.youtube.com/watch?v=bJmZjPxyoWY
Things that made it go easier:
1) Knowing that the extension was there, next to the firewall, and a pain to remove...
2) Knowing exactly where to look for the nipple to drain the coolant. I knew where it was and I still had a hard time locating it until I removed the water shield underneath and got just the right angle. (from under the
front of the vehicle)
3) Using the 'small profile' quick-connect tools instead of the ones with the handles. (Don't use the ones in the video)
4) A 90 degree, long handled, needle-nosed pliers. This tool was GREAT! I borrowed it from O'Reilly's. The manager had to replace the same hose in the past and told me it would be useful. OH YEAH IT WAS! When trying to get to the back of the extension, this tool helped me get the quick-connect tool into place in that small space, and then I was able to use it to apply back pressure BEHIND the quick-connect tool in order to push against since the firewall has a small piece of black foam behind the extension which wouldn't provide any support when trying to press the quick-connect into the coupling.
5) Having a beautiful assistant to hand me what I needed as I had to literally lay across the engine in order to reach deep into the back of the firewall and still be able to use my arms
6) Having a good light set up to see back by the firewall.
Getting that extension off was definitely a 2 beer accomplishment in itself!
Now here was my bonus:
Prior to the hose replacement, the computer was reading a misfire in the third cylinder. It was VERY obvious in the performance, skipping and lurching under heavy acceleration. (not that I have a lead foot or anything... well OK - I do.) I feared the leaking coolant had damaged the coil and it too would need replacing. I only hoped that after drying up the coolant around the coil bases (1,2, & 3) that the skipping would go away and I not have to replace a coil.
Also something I had noticed since I bought the truck a few months ago was the obvious and ludicrous shifting the computer did with the transmission. I constantly complained to my beautiful wife how I hated computers in vehicles because a 5.4 liter V8 has WAY more power available in it than this computer was allowing the truck to put out. I want to rip it out and stick a metal rod through the floor so I can shift it MYSELF! I'm sorry, I want my own control over things... it must be the republican coming out in me.
Well!- On the first test run after refilling the coolant ... NO SKIPPING! YAY! AND... the computer allows the truck now to really use its power. From a stop it actually rubbed the rear wheels on take off and through the first several gears it allowed red-line to be achieved and shifted rapidly! The difference in power just from replacing this leaky hose and cleaning off the coils was SO obvious that my wife sitting next to me had a giddy grin on her face as we slammed through gears and the big V8 roared. Granted- it's still a big lumbering Expedition EL, but finally the power of the V8 is revealed.
I'm so excited!
Good luck to the next of you to replace it!
